Hello,
I'm trying to parse a MSI file to determine if it's a single file or not.
If not, I want to determine the name of the dependant files or directory.
Could you tell me in which propertie is it stored?
Thank you very much.
Single MSI package or not ?
edreux
, Nov 23 2010 14:37
Posted 24 November 2010 - 10:56
You mean you need to find out if the application files/CAB are stored inside the .msi file or separately? If it's internal, then there will be a separate stream for it inside the COM Structured Storeage which is the format of the msi file.
Posted 24 November 2010 - 21:13
Hi Stefan
thanks for your answer. You exactly understood my need.
Since I'm doing it programmatically, what I suppose I need is the name of the property where it is stored:
Here are the main lines of code:
WindowsInstaller.Database database = InstallerObj.OpenDatabase(MsiFilename, MsiOpenDatabaseMode.msiOpenDatabaseModeReadOnly);
View view = database.OpenView("SELECT `Property`,`Value` FROM Property");
switch (Property)
case "ProductCode":
Result.ProductCode = Value;
break;
case "UpgradeCode":
Result.UpgradeCode = Value;
break;
etc...
I tried to browse the MSI with MSI viewers utilities and did not manage to determine where it is stored.
Regards.
switch (Property)
case "ProductCode":
break;
case "UpgradeCode":
break;
etc...
Regards.
Posted 25 November 2010 - 13:19
It's not in a property. It's not in the msi database itself.
In the msi file, which is a COM structired storage (like a file system inside a file), there are multiple streams: the msi database, the summary information stream (which does have a flag to indicate compressed or loose files, but not external or internal) and optinally a stream the holds the CAB file if it has been streamed into the msi file instead of using external CAB.
