Is there any way to update the MSI 2.0 service using ISWI 2.01? I found several articles on updating the setup.ini file with the [Supportos] stuff and MsiVersion changes, but i tried this and it does not work.
On the InstallShield site Document ID: Q105501, it lists that a new setup.exe needs to get put on your CD. But this mentions that it is only good for the 2.03 version.
Any help would be appreciated.
thanks in advance,
-daren kobata
Installing MSI 2.0 Engine With ISWI 2.01
darenko
, Apr 22 2002 23:05
Posted 24 April 2002 - 20:09
I don't know if it will work with 2.01. But why don't you use 2.03?
Posted 24 April 2002 - 20:58
I can't use 2.03 because the upgrade from 2.01 to 2.03 does not build. I get the -3705 error can't build custom action table. But if you look at the SetupCompleteError dialog, the SetupInterrupted dialog and the SetupCompleteSuccess dialog the sequence numbers are correct -3, -2, and -1. There is nothing wrong with my custom actions. They worked in 2.01.
Also, when I look at my upgrade table, the upgrade demolishes it and I can't put the values back in. Even if I delete all custom actions, I still get the error. I think there is a bug with the upgrade and somehow it hoses my project.
any ideas?
thanks in advance,
-daren kobata
any ideas?
thanks in advance,
-daren kobata
[b]darenko[b][br][i]darenko[i][br][b]installer[b][br]
Posted 25 April 2002 - 16:37
Under Windows Installer -> Tools and Tips -> Launchers and Runtime Installers there are some tools that you can use to replace InstallShield's setup.exe.
