Hallo
i use is10.5 mutli instance installation mode but my installer runs always in a first installation.
I convert my project from is6.3 to is10.5
When i use a sample project and multi instance installation => this works fine
my own project not :-(
Does anybody know about problems with the 'multi instance installation'
need help, urgent!
Chris
MULTI_INSTANCE_COUNT is not set
CMartin
, May 30 2005 16:46
Posted 31 May 2005 - 14:23
Are you using the (new) event driven script model, or the old program - endprogram style? I believe multi-instance will only work with the first, not the latter.
Posted 31 May 2005 - 14:36
the problem is solved!
there were two GUIDs
project GUID and in a script to optimize setup.ini the orginal ProductGUID was overwritten.
thanks
Chris
thanks
Chris
Gruss
CMartin
CMartin
