Hello,
I use InstallShield Professional 5.5. I have a problem using RegDBGetKeyValueEx on a system that has OfficeXP installed. For some reason this correctly retrieves a value from the registry:
nvResult = RegDBGetKeyValueEx ( "\\Software\\Microsoft\\Office\\10.0\\Access\\Settings" ,
"MRU1" , nvType , svTempStr , nvSize );
But this fails to retrieve the value sought:
nvResult = RegDBGetKeyValueEx ( "\\Software\\Microsoft\\Office\\10.0\\Word\\Data" ,
"Settings" , nvType , svTempStr , nvSize );
Even though that key and value do exist in the registry according to Regedit.exe. Has anyone run into this and found a fix?
Thanks. - John
Registry Issue
JohnImhoff
, Aug 31 2002 01:11
Posted 31 August 2002 - 11:11
A few things to check:
Get rid of the leading backslash in front of Software. (You should never have a leading backslash there)
Make sure you have set the correct root key. Note that some InstallShield functions reset that selection so you should call RegDBSetDefaultRoot immediately before your RegDBGetKeyValueEx call.
Make sure you have sufficient rights to access that key. Not sure if Read access is sufficient for InstallShield (they may try to open the key in read/write mode)
Check the return value from your function call (nvResult)
