I have the next problem.
In my installation, the setup.exe file (or .msi database) is installed in the TARGETDIR (the installation folder selected by the user). Then I make a shortcut to that file to allow user to uninstall/repair the software without using Add/Remove Programs on Control Panel.
When I uninstall the program using Add/Remove Programs, all files and directories are removed properly. But when I uninstall the program using my shortcut to the msi database, the installation folder (TARGETDIR) is not removed and is left empty.
I know is logical because a directory that is not empty can't be removed by the installation, but I need that shortcut.
Does anybody know haw can I solve the problem????
I use Orca to create the Installation Database.
Thanks in advance.
Need help on uninstallation
the_force
, Sep 01 2003 11:31
Posted 01 September 2003 - 23:11
Do you have to use setup.exe to uninstall your program?
You should be able to use the msiexec executable to remove your program. HAve a look inside the registry under
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
See what the other products have their uninstall string set at. You should then be able to create one for your install.
