Hi to all,
why InstallShield 6.31 Cabinet File Viewer can't open .cab files and .hdr files belonging to an InstallShield 5.5 setup?
It return a severe error:
Error number: 107
Description: Could not initialize compression engine
Are there any other ways to open these files?
Thanks.
Ciao, Giuseppe
P.S.
It seems to me that failing to open InstallShield 6.31 .cab/.hdr files with InstallShield 5.5 Cabinet File Viewer (compatibility in advance) is acceptable and logical but not the contrary (backwards compatibility)!
If I only have IS6.31 but I also have a lot of old IS5.5 setup (left from previous management) how can I do if I want to (for example) extract a file?
Question about IS cabinet file viewer
gronchi
, Nov 13 2002 12:13
Posted 13 November 2002 - 17:50
I've never needed to use the Cabinet File Viewer, but worst case you could re-install IS 5.5 on a box and copy off its viewer executable.
Posted 15 November 2002 - 18:01
| Quote (TacoBell00 @ Nov. 13 2002,16:50) |
| I've never needed to use the Cabinet File Viewer, but worst case you could re-install IS 5.5 on a box and copy off its viewer executable. |
Installing IS55 the IS6.x cab file viewer will open cab/hdr file packeged with IS55, that's ok.
But I have another problem: I want to build a IS6.x project (and deliver it) that can do the following (once installed onto target machine):
it could open cab/hdr file of IS55/IS6.x package. For example from CDROM's setup.(*)
Now I obtain this with ComponentInitialize and ComponentGetData but my project has the same problem of cab file viewer (that is, if I build it with IS6.x it reach to open only IS6.x setup).
I think, unfortunately, also installing IS5.5 onto my machine this restriction will remane the same, isn't it?
Is there a way to provide the IS6.x engine the ability to open IS5.5 cab like it happens with the IS6.x cab file viewer?
Ciao
Giuseppe
(*)I hope I was been clear in my exposition, anyway we need to extract component information of old setup and we are studying a way to do that with another IS setup. This way has to be as automatic as possible, so I prefer a project rather than open cab file viewer any time.
Posted 19 November 2002 - 01:51
Responding here instead of Messenger, so all may contribute and learn from this experience.
Yikes! Well I've never used IS5, only IS6 so I'm not the one to answer this question.
However, my I suggest simply delivering your source data files in uncompressed format, so you nee dent bother with all these differing CAB file formats later on.
