Hi...
I am using InstallShield 2010, Ver 16.X. and working on Basic MSI Project.
There is specific requirement that a Custom actions needs to be called on Click of Next Pushbutton of InstallWelcom dialog.
Scenario - i have a Custom action of type InstallScript. This calls one function given below.
Custom Action Sequence Problem
rpatil
, Dec 17 2009 13:01
Posted 17 December 2009 - 13:01
| export prototype BeforeLicenseAggrement(HWND); function BeforeLicenseAggrement(hMSI) STRING szCommandLine; begin SdShowMsg('Gathering System Information...', TRUE); lbl_CheckUserIsAdmin: //Do some work lbl_CheckDatabse: //Do some work lbl_InstallRunTimes: //Do some work lbl_StopCluserServices: //Do some work Delay(10); //slight delay to allow time for the service to start Enable(HOURGLASS); SdShowMsg('Gathering System Information...', FALSE); end; |
If i edit the behavior of InstallWelcome, On Next Click, I have specified following actions.
I call above function by specify an event as given below,
| Event Argument Condition DoAction BeforeLicenseAggrement 1 |
After completing this CustomAction, next action is to go to LicenseAgreement dialog as specified below,
| Event Argument Condition NewDialog LicenseAgreement 1 |
1. Both the action are geting executed but, After the Click of Next button the welcome screen doesn't get disappear. How should i do that?
2. When i say back from the LicenseAgreement Dailog and again says Next on InstallWelcome the above metioned actions need to be executed, how should i do that?
Please help.
Thanks & Regards
rpatil
Edited by rpatil, 20 December 2009 - 12:51.
Posted 18 December 2009 - 07:29
| QUOTE (rpatil @ 2009-12-17 13:01) |
| Event Argument Condition DoAction LicenseAgreement 1 |
You should change the Event from DoAction to NewDialog.
Because LicenseAgreement is Dialog not CustomAction.
Posted 23 December 2009 - 12:01
| QUOTE (rpatil @ 2009-12-22 21:15) |
| Please help me..... |
Did you follow yus' advice? Did it help What are the symptoms now?
