ISWI 2.01 - I have a feature that I only want installed if a radio button property is set to a certain value - basically I'm rolling my own Setup Type dialog....
The feature (default level = 200, INSTALLEVEL = 100) has a condition of
Level: 1 Condition:INSTALLTYPE < 3
I have a group of radio buttons built around the INSTALLTYPE property, which has a default of 1 in the property Manager
If I select the radio button which set's it to 3 (and the value is displayed on the next dialog as a debug check), the feature STILL gets installed.
However if I set the property to 3 on the command line whne I launch the MSI, then the 3rd radio button is then selected as expected, and the feature DOES NOT get installed.
From this I can only deduce that the feature conditions are evaluated before the UI sequence is run, which seems just plain wrong.
Anyone else have experience of this?
Cheers
Ant
