Hello,
I have IS 10.5.
I have a Component named PARAMETER.
The Componenent holds 3 Files.
One of these Files is marked as a Key File and hast the attribute Always Overwrite
Now to the Problem:
In the new Setup, the Version of the Key File is changed from - say 1.1.1.1 to 1.2.3.4.
When running the new Setup, the KeyFile is not overwritten with the new one.
Any Ideas where ro have a look, or what to change?
Thanks in advance.
Dieter
Always overwrite not working
Dieter.Soergel
, Feb 07 2008 13:39
Posted 08 February 2008 - 00:16
Look at the file version number in the built .msi file. It should be a high number, I think InstallShield puts 65535 as version number to mimic the "always overwrite" behaviour. A log file should also tell you.
