We need a highly customised UI for our install and for this reason we are choosing Install Script project. The application needs Web Service Extentions 2.0 that comes only as msi redistibutable. How can I run this msi from inside the IS project? LaunchAppAndWait is not working, so is DoInstall.
Thanks, B
How to run an MSI project from an IS project
bijuishere
, Mar 04 2006 01:50
6 replies to this topic
Posted 06 March 2006 - 17:20
LaunchAppAndWait should work. How are you calling it, and what are the results (return code from the function, returned exit code from msiexec)?
Posted 07 March 2006 - 04:16
Hi Stefan,
Thanks for the reply.
The return code is -1. I have no idea how to get the exit code out of the MSI. Could you please guide me on this.
Thanks --B
Thanks --B
Posted 07 March 2006 - 17:17
Are you using the MSIExec function to call your msi? example:
Sprintf(szParams, "/i %s", "YourMSI.msi"); nResult = LaunchAppAndWait("msiexec.exe", szParams); if (nResult < 0) then Sprintf(szMsg, "The app failed to launch and returned error code %d", LAAW_PARAMETERS.nLaunchResult); MessageBox(szMsg, INFORMATION); endif; |
Then you can look up the error code at Microsoft's pages :http://msdn.microsof...error_codes.asp
You can look up msiexec in your InstallShield help to find all of the options available.
Good Luck!
-- spdygnlz --
Posted 07 March 2006 - 19:04
Now it works!!!
I was trying this before. Which was not working
nResult = LaunchAppAndWait("c:\\wse.msi","/q",WAIT);
And I started doing this
Sprintf(szParams, "/i %s", "c:\\wse.msi /q");
nResult = LaunchAppAndWait("msiexec.exe", szParams, WAIT);
Now I see the wse setup launching.
I hope for msi one needs to call then this way. (I didn’t know that)
Anyways Thanks a lot spdygnlz and Stefan . Appreciate it
I posted this question at the InstallShield support and got no reply
Posted 07 March 2006 - 19:26
LaunchAppAndWait can only launch executables.
