I have got an application, precisely two versions of an application.
Each of both version consists of one .MSI and one .CAB files.
How to create a patch .MSP from first version to second one?
I am trying to accomplish this with following:
patch and .CAB
jumi
, Apr 20 2004 13:13
Posted 20 April 2004 - 13:13
| Msimsp.exe -s Patch2.1.13_2.2.0.pcp -p patch_2.1.13.0_2.2.0.0.msp -l patch_2.1.13.0_2.2.0.0.log |
I am getting this error:
| ERROR: UpgradedImages.MsiPath 'Version213.msi' is marked as having compressed files (PID_WORDCOUNT property of Summary Information stream). PatchWiz is unable to patch files compressed in a cabinet. |
I am not able to involve .CAB in patch creation process...
Posted 20 April 2004 - 18:23
You need to unpack the CABs. To do this run an administrative install (msiexec /a) of the packages to uncompress the files.
Posted 21 April 2004 - 12:25
Thank you, I did that administrative installation.
Now, when I try to create patch, I am getting:
ERROR: TargetImages.Target = 'Coban_Old213': PackageCode {42AD1DC2-479C-11D6-93F3-0060080F0770} is not unique. |
42AD1DC2-479C-11D6-93F3-0060080F0770 is ProductCode accross all versions of the application.
Posted 21 April 2004 - 13:54
I found a hint in the thread "How to create small update, What are the step - by - step procedure". It was needed to change Revision Number in Properties of a .MSI file. I got a .MSP yet. I will test it to see whether it is usable.
Posted 22 April 2004 - 10:20
Yes, it is important that you change the package code GUID whenever you rebuild your msi file.
