Hi
Solve this... please!
I use InstallScript to create registry entries and delete them (and not IS7 registry explorer since there are other registry entries that I must remove that are only created while using the application) as follows :
FeatureName_Installing - RegDBCreateKeyEx and RegDBSetKeyValueEx
FeatureName_UnInstalled - RegDBDeleteKey
Now when I do a Major Upgrade (similar InstallScript in newer Version) the registry entries as per the newest version are created during installation and then deleted after I click "Finish". I suppose this is because I used FeatureName_UnInstalled and not FeatureName_UnInstalling. However the previous version is already in production so I need to get around this.
How do I stop these registry entries being deleted?
Please note I have the RemoveExistingProducts after InstallValidate and before InstallInitialize. (Have also tried it after InstallFinalize). Also note that if no previouse version is on the machine it works fine. Also if I Click repair after the major upgrade the registry entries are fixed.
Thanking you in advance.
Jason
Upgrade removes registry entries
jasonspriggs
, Sep 09 2002 17:43
Posted 22 January 2004 - 14:55
If you haven't already solved this issue, it is a known issue with InstallShield Developer, when using InstallScript based installs.
http://support.insta...ticleid=q107649
Very annoying and causes many headaches....
Posted 02 March 2005 - 09:05
I followed your Resolution step to upgrade the InstallShield. Rebuild my setup project again and test the upgrade installation is still failed.
After I click Finish button, my copy files delete automatically. Why not?
I use InstallShield V7.04.
My project is emergency, please help me.
Daniel
Daniel
