Hi there,
it seems that IS 5.5 doesn't warn the user if he installs to a disk with unsufficient diskspace. Therefore I wanted to check the free diskspace with a script. Does anyone know how I can check for free diskspace ? The GetSystemInfo only returns the total amount of my harddisk.
Thank you
Get free diskspace
cyberdelic
, Nov 28 2002 11:48
6 replies to this topic
Posted 28 November 2002 - 16:59
another option might be to use the OutofNoRbDispSpace property. this property is set after the CostFinalize action. this property will be set to true if the target of an installation has insufficient space...
Posted 28 November 2002 - 17:00
finger foul up property name is: OutofNoRbDiskSpace NOT/NOT ...DispSpace, sorry
Posted 29 November 2002 - 20:15
hambone's suggestion would work only with InstallShield Developer, but we're talking about Professional 5 here.
The function that cyberdelic is looking for is probably GetDiskSpaceEx
Posted 03 December 2002 - 20:27
thanks stefan, i wasn't aware that there was a GetDiskSpaceEx in Professional. that seems like a more elegant solution!
the OutofNoRbDiskSpace property i was referring to is standard for msis and, as such, should be supported by all of the tools ?
Posted 06 December 2002 - 13:06
GetDiskspace and GetDiskspaceEx return the whole diskspace on my drive, not the remaining diskspace ! Does anyone know how I can check the remaining diskspace ? Thanks
Posted 08 December 2002 - 14:48
hambone: Professional 5 is not MSI based
cyberdelic: it should return the free space
