I am using Basic MSI Project.
I am trying to install Java Run time envionment1.6update25 from Install shield custom action at Install Finalize exec sequence.
But it is cancelling installation in between.
if i am executing the jre-6u25-windows-i586-s.exe manually it is executing properly.
if i am executing jre-6u25-windows-i586-s.exe at finish button it is working properly.
I just wanna know why at Install Finalize it is not working and how can i make it work at at Install Finalize exec sequence.
any help will be appreciated.
Thanks & Re grads
Abhijeet
Java1.6update25 Installation Issue
abhijeetkusre
, May 05 2011 13:42
Posted 05 May 2011 - 14:48
As far as I know the Java installer is also msi based, and only one msi setup can be in execute sequence at any time. You could install Java as a prerequisite instead.
