Hello,
I have installed my installation program, and delete the
installed file without remove my installation program. So,
Repair function pop up to repair the file I have deleted.
Is there any way that I can disable the repair function ?
And
Is there any way to check which file is repaired by the msi ?
Repair option
stchin
, Aug 28 2002 05:13
Posted 28 August 2002 - 14:52
hi there,
although there is a DISABLEMSI policy there is no way to stop the auto-repair ( other then to edit the component(s) and remove the KeyPath...), sorry
Posted 28 August 2002 - 15:38
sorry, there is one other way that i know of....
that is to add the component to another component that has a different keypath.
that way the file in question will only be re-installed/repaired if the new merged component's keypath entry is missing. if you opt to do this you should change the GUID for the newly merged component...
Posted 30 August 2002 - 11:51
A slightly better way to do it rather than making it a companion file is to move such file/component into its own feature you can then run the package to just remove the single feature,component and file.
Ian Blake
(Currently Unemployed)
