In the documentation for Crystal 8 merge modules it says that I need to add these two registry keys.
1. The registry key should be: [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Paths\MyApp.exe] and should have a default value that points to the full path of the executable, such as [#MyApp.exe]. This is a formatted data type that is case-sensitive and that Windows Installer will set during the execution process.
2. Create another key under […\App Paths] named “Path” and set it’s value to “[$MyApp.exe];[WindowsFolder]CRYSTAL;[ProgramFilesFolder]Seagate Software\Shared;”. [$MyApp.exe] is another formatted data type that points to the parent folder of the main executable, MyApp.exe in this example.
But my program does not consist of any executables. All I have is DLLs and ASPs since my program is a web based program. Do I have to add these registry keys still.
Thanks for all the input
