This post is just to ask the question.... "Is it possible to do this and allow the main MSI file to 'keep control' of the sub modules without having to run each script separately."
The reason for doing this is so that I can write one generic oversetup which without modification can support extra sub-modules. It also means other developers can write the file installation routines for there components without the main setup having to install any files (directly).
I hope that I have explained the problem clearly enough and if anybody could give me some advice I would really appreciate it! I am using the newest release of InstallShield if that helps.
Thanks in advance
Paul
