Hello,
I want to install a program which uses SQLDMO. In this case, on target machine if SQL Server is installed then i dont want to copy SQLDMO.dll and related DLL's in other case where SQL Server is not present I want to copy these DLL's.
The solution I did was I created a Global Property SQLDMO_PRESENT. I used SYSTEMSEARCH and searched SQLDMO.DLL on the target machine.
and the components section in the properties of each DLL i added the condition SQLDMO_PRESENT <> ""
And this worked. But now its having some problems.
Can any body tell me how to do the above .
thanks
Ninad
Conditional Installation of DLL's with the setup
ninadbhise
, Nov 03 2003 07:33
Posted 03 November 2003 - 12:24
That depends on what problem you now have.
I doubt that you can redistribute sqldmo.dll on it's own. I think you need to install SQL Server or MSDE.
Posted 10 November 2003 - 17:29
I managed to create MSMs for SQLDMO v. 7 and 2000 (sorry, cannot give away these).
I enforce two requirements: IE 5.01 and MDAC 2.6sp2. (The latter is also installed, when omitted.) These requirements are probably not necessary for SQLDMO 7, and maybe not even SQLDMO 2000, but I had no time to figure this out.
Deployment is described in the deployment text (REDIST.TXT). I include the original (non-SP) versions of both SQLDMO 7 and 2000. With respect to DMO2000, the file Sqlunirl.dll does not have to be included: it is part of MDAC 2.6.
My installation always installs SQLDMO - it does not try to detect existing versions. One of the reasons is that software like MSDE can be uninstalled, and SQLDMO goes too.
Hope this helps.
Hope this helps.
