Im trying to use script to set the installation directory my installation has 2 features, both of them is set to be installed at [INSTALLDIR]
running this script to update the value of the [INSTALLDIR] does not take effect, and the default dir still set.
I haveverified that the registry key is valied and the value is properly exctracted....
Ofer
here is the script:
szKey = "SOFTWARE\\key";
szName = "InstallDir";
nType = REGDB_STRING;
szValue = "test";
nSize = -1;
RegDBSetDefaultRoot (HKEY_LOCAL_MACHINE);
nRetvalue = RegDBGetKeyValueEx(szKey, szName, nType, szValue,nSize);
if (nRetvalue < 0)
then
MessageBox ("failed to get installation dir from registry", SEVERE);
abort;
endif;
setPathresult = MsiSetTargetPath(hMSI,"INSTALLDIR", szValue);
if (setPathresult == ERROR_SUCCESS)
then
MessageBox("ok", SEVERE);
endif;
using installscript to change installdir
oferir
, Mar 03 2009 12:14
Posted 12 March 2009 - 21:16
| setPathresult = MsiSetTargetPath(hMSI,"INSTALLDIR", szValue); |
This function is only available in MSI projects. I would expect you get a compile error when using it in a pure InstallScript project.
Instead you can directly set INSTALLDIR:
INSTALLDIR = szValue;
