I'm trying to install a component (MSWord template) to Word's startup folder.
I've setup a AppSearch item looking for the registry value, but the property never gets the value. Thus, the component is installed to [TARGETDIR].
Using InstallShield Developer 7.04
Any ideas on how to accomplish this?
Install to Preexisting Location
dhover
, Sep 19 2002 20:32
Posted 23 September 2002 - 23:37
All you should have to do is setup the appsearch table correctly. This should then set a property, which you then must use as your destination for your component.
Posted 23 September 2002 - 23:42
Sounds easy enough, doesn't it?
I've tried setting it up according to the documentation, I've done it using the wizard, I've tried it in what seemed to be a logical manner, and I've even tried setting it up unlogically. All to no avail.
Can you give step-by-step instructions for setting it up correctly?
dhover
dhover
Posted 01 October 2002 - 17:01
HI,
Thsi is a sample.
1. AppSearch table:
Property DESTDIR (upper case)
Signature DestDir
2. RegLocator table:
Signature DestDir
Root 2 (HKLM)
Key Software\....
Name ValueName
Type 0 (to get a path)
3. Directory table
Directory DESTDIR
Direstory_Parent TARGETDIR
Default_Dir .
Then set a component destination as [DESTDIR].
You can create a simple custom action to show this property to make sure it is set correctly. It is easy with VB script.
Custom action Type 102
Source (empty)
Target MsgBox "DESTDIR = " & Session.Property("DESTDIR")
Insert this custom action after AppSearch
Good luck,
Thsi is a sample.
1. AppSearch table:
Signature DestDir
Signature DestDir
Root 2 (HKLM)
Key Software\....
Name ValueName
3. Directory table
Directory DESTDIR
Default_Dir .
Source (empty)
Good luck,
Irina Shirinsky
Software Engineer, Heroix Corporation
http://www.heroix.com
