When installed a program, in Add/Remove Programs panel, select the
installed program and you can find the "Change" button (or "Change/
Remove") button. Normally when click this button windows will show the
msi maintenance UI, but now I don't want this msi maintenance UI but
another program which is designed by myself, how to do this?
Thanks very much for your help.
how to use "change" button in add/remove programs
WisperWind
, Feb 28 2007 02:45
Posted 28 February 2007 - 08:13
Set the ARPSYSTEMCOMPONENT property to 1 to prevent Windows Installer from creating an Add/Remove entry. Use the Registry table to create the entry yourself.
Posted 05 March 2007 - 10:53
If you let Windows Installer create the entry it will display two separate buttons for Remove and Change. For non-MSi setups, or if you set ARPSYSTEMCOMPONENT and create the uninstall registry entry yourself, there will be one combined button Change/Remove.
