All,
I have an English(no extra languages included, just the default project) Basic MSI project.
I have some files within the language independent support files.
However, since yesterday I encountered that, for installing SQLExpress2005(where I use a SQLServ.ini file for to trigger the installation), I need language specific SQLServ.ini files.
My question: what do I need to do to be able to put the translated SQLServ.ini(for English, French, Italian, Spanish, German and Russian) within the language specific support files folders?
I have enabled these language within the project - settings - language tab, so I get the language specific support files folders. However, when I test the project on a german OS, I still get the english SQLserv.ini file.
Can someone explain me how the extraction of the language specific support files work?
Thanks!
Cheers,
Christoph
Support Files - Language specific
Christoph
, Apr 25 2007 20:53
Posted 30 April 2007 - 17:36
Is your setup running with German UI in this case? Or are you still runing the English setup on a German OS?
Posted 03 May 2007 - 15:54
I believe that the language specific support files are filtered based on the setup's UI language.
If you need to install files based on the OS language you can place them in separate components are condition tham using the SystemLanguageId property.
