Hi all,
In my installer it contains a mergemodule which has a dll to register my extension, originally I added a *.reg file to the Component dll "REG File To Merge At Build" to write the info to registry...the problem is when it un-installs the old version product and then installs the new one...the old icons on the Desktop are not updated, but open the dialog to select a *.* file, in the Open dialog, the new icon is used.
After reboot, the icons can be update...but I don't want that...I don't want to ask the user to reboot just because the icons haven't refreshed
And I have tested if use 'regsvr32' to register the dll after install, the icons can be refreshed...but I can't find a way in IS to register it to make icons refresh without rebooting...I have tested to use self-register and add the dll to the self-reg table.It doesn't work.
Does anyone know how to resolve this problem?
Cai xiaoqing-Hermione
How to refresh icons without rebooting?
HermioneJJ
, Apr 21 2006 10:12
Posted 21 April 2006 - 10:47
Try deleting IconCache file.
Or if there is any other better way (thru code) i would love to know that.
ankur tyagi
Posted 21 April 2006 - 11:45
Thanks, antyagi!
Could you please tell me how to deleting IconCache file? I don't know where is it.
Posted 22 April 2006 - 03:42
There is a windows message that can be sent to refresh the icons (at least on the desktop). I don't have access to the code for this at the moment, but this would be significantly cleaner than deleting the cache!
Posted 24 April 2006 - 14:44
Thanks.
I have test the function SHChangeNotify...it only works when you un-install the product and delete the key [ HKEY_CLASSES_ROOT\**file\DefaultIcon]...it can refresh the icon to system's default unknow icon.
But it doesn't work in my problem. un-install the old and then install the new one the icon still the old..however I fixed it by another way.That is:
Change the Dll which contains the icons and so, the value of the key [ HKEY_CLASSES_ROOT\**file\DefaultIcon] different between the old and the new...in that way the IconCache changed. And system will show up new icon without reboot.
Posted 04 May 2006 - 12:09
yes, ChangeNotify is a cleaner approach.
by the way what arguments you have passed to SHChangeNotify?
ankur tyagi
