Hi!
I know how to execute a custom action during installation. It works great.
Now I would like to execute a custom action when the user uninstalls the application through 'add/remove software' in the control panel.
I was able to execute this custom action when the user uses the MSI file to uninstall it but I can't force the user to use it; he may have deleted it or simply used 'add/remove' instead.
I have the sentiment this is a common use of an installation system but I have not found this topic in the docs. Is it possible to do?
Thanks in advance,
Mathieu Routhier
Executing an Action when Uninstalling
mrouthier
, Mar 16 2002 23:15
Posted 17 March 2002 - 23:21
There is no difference executing a CA when installing or uninstalling. There are a few points to be aware of.
You can not call a CA installed with the product after it has been removed.
You should not call a CA on the installation media because the installation source may not be available.
I think it is best for CAs called by the installation to be placed in the binary table so they will always be available.
Posted 17 March 2002 - 23:58
You gave me an hint !
Solved !
For the people interested, I was placing my CA in the InstallUISequence. I moved it to the InstallExecuteSequence table and it now works number one.
Mathieu Routhier
Mathieu Routhier
