I am working on installshield MSI project. (ISD10.5 professional). I am using one dll. (installhelper.dll) in this project.
i am calling some dll function in the script.
But when I am trying to load the dll using
UseDll( SUPPORTDIR ^ "InstallHelper.dll"); function then UseDll function failed to load it and return -1 value.
Installation popup the error message showing error number: 0x80040702
i have checked in the Temp folder during installation and found dll is copied there.
I have checked the dependency and copied all the dependencies in SUPPROTDIR during setup execution.
still its failing and not able to understand why so?
Can anybody tell me, why?.
if anyone can help in this regard then it will be very grateful.
shekhar
UseDll function fail to load the DLL
Shekhar
, Oct 11 2006 09:56
Posted 20 November 2006 - 05:22
We are having a similar issue with UseDLL(). We are loading a Dll like this after doing a changeDir() to the support directory.
szDLLPath = SUPPORTDIR ^ "ICServerInstallA.dll";
if ((nReturnValue = ChangeDirectory(SUPPORTDIR)) < 0) then
NumToStr(szMsg, nReturnValue);
MessageBox(" ChangeDirectory() Error. Directory : " + SUPPORTDIR, SEVERE);
MessageBox(" Error code : " + szMsg, INFORMATION);
endif;
if( (nReturnValue = UseDLL(szDLLPath)) < 0) then
MessageBox(@ERROR_LOADING_INSTALL_DLL + " " + szDLLPath, SEVERE);
abort;
The exception -
Unhandled Exception
Error Number: 0x80040702
Description: Failed to load dll: ICServerInstallAD
Setup will now terminate.
OK
1. The Dll is streamed to the support directory and is in the support dir
2. There are NO missing dependencies.
Any suggestions/solutions will be of great help ....
Thanks, Raj
endif;
abort;
The exception -
Unhandled Exception
OK
Thanks, Raj
Posted 09 July 2007 - 08:29
After a lot of searching the problem appeared to be connected to the C Runtime library DLL, msvcrt.dll. Changing our DLL so that it linked statically to this (compiling our code with the /MT option instead of the default /Md) fixed the problem.
