Looks like Stefan had to clean previous posts but the gist of it was that the code you want to be common should be in a rul file and placed in the IS app dir which contains all its rul files. Then you just #include it in your script. You probably can put the #include in ifx.rul or someother file that is always included and it will always be available without the individual #includes in the different projects. This is if the code is static (and we are thinking of the same previous post.)
If the common code is changes, you can use a custom object and when it is rebuilt it will be registered and when other projects are rebuilt they will contain the updated object.
(Edited by lasenbby at 8:28 pm on Dec. 5, 2001)
