Does anyone know a solution for the following problem:
We have a demo-shield project who starts a master setup.
The master-setup starts multiple sub-setups ones at a time.
If we start it from the network, there's no problem.
If we burn it on cd we got problems.
The demoshield starts the master-setup.
The master-setup starts the sub-setups but don't wait till the are finished.
So all sub-setups running at the same time.
The strangest this is that the DoInstall function return 0
He just don't wait.
Even with a LaunchAppAndWait it don't works from cd.
We even tried a ChangeDirectory.
So it's a bugg in IS 12.
Does anyone knows a solution for our problem?
Upgrade projects from IS 10.5 to IS 12
svermassen
, Oct 01 2006 18:51
Posted 03 October 2006 - 07:34
What is so special about LaunchAppAndWait . You can try using LAAW_OPTION_USE_CALLBACK option to specify the callback interval.
It is also written in help that LaunchAppAndWait uses the same directory as default when launching a new program. So it could be something with the CD-R media, so use ChangeDirectory first and then run the additional setups.
glad if helped
shino
glad if helped
shino
Posted 03 October 2006 - 12:55
| QUOTE (shino @ 2006-10-03 07:34) |
| What is so special about LaunchAppAndWait . You can try using LAAW_OPTION_USE_CALLBACK option to specify the callback interval. It is also written in help that LaunchAppAndWait uses the same directory as default when launching a new program. So it could be something with the CD-R media, so use ChangeDirectory first and then run the additional setups. glad if helped shino |
We use the full path with SOURCEDIR ^ PATH FROM INSTALL.
The LaunchAppAndWait automatically does a ChangeDirectory.
Posted 07 October 2006 - 14:05
Does anyone know a solution for our problem???
Is this a bugg in IS 12 ???
Posted 27 December 2007 - 16:16
You have to use /clone_wait as a command-line parameter due to changes in the DoInstall logic documented in IS KB article Q112115
