Hi
I wrote an MSI project.
This Project contains one Merge Module.
I want to pass to this MSM a parameter which its value is being determined during the installation process (which means in runtime).
As I know that the Custom Action Code of the MSI runs after the the Custom Action code of the MSM.
Can I achive the following goals:
1. MSI code will run before the MSM code.
2. the MSI will pass a parameter to the MSM.
Thanks a lot
MSM - PAssing Parameters
Mr.B
, Jan 12 2006 07:24
Posted 12 January 2006 - 15:08
A custom action in a merge module will run whenever it is scheduled to in the main installation, as does a custom action in the main installation.
You should be able to schedule your merge module's custom action to execute wherever you need it to execute. Take a look at the ModuleInstallExecuteSequence and ModuleInstallUISequence tables in your merge module.
Kathy Morey
Synergy Software Engineer
kmorey@profitstars.com
Posted 12 January 2006 - 22:22
I've seen the following method used (and did so myself):
The MSM-developer defines a property (eg. [MSM_Help_Language]), and implements its logic. The MSI developer reads the property definition, and sets this property accordingly.
Posted 17 January 2006 - 05:34
In your MSM, you will need to code the custom action to use a global property (all capitals). You can then set this property in your main installer and the merged in custom actions from the MSM will use that.
