Getting the list of ODBC Data Sources
bjh
bjh
  • Members
  • 25 posts
Posted 19 June 2001 - 15:01
I have to build a custom dialog that displays a list
of the defined ODBC Data Sources (User defined and
system defined). The user has to choose one of them
and the setup takes its name and saves it in a file.
Any idea about how this can be done?
Jean
tgebbie
tgebbie
  • Members
  • 26 posts
Posted 19 June 2001 - 17:20
ODBC Settings are stored in the register HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\
Here is an example from my system:
[HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\axcms32]
"Database"="axcms"
"Description"="INVISIC System 3 SQL Server Data Source"
"Driver"="C:\\WINNT\\System32\\sqlsrv32.dll"
"LastUser"="cmsuser"
"Server"="platinum"
"AnsiNPW"="No"
You then could use the InstallScript Registery functions to query the registery then store their values into a string table.
TDG
