I'm using Patch Design from InstallShield 2008 - Premier to build a patch "Update.exe".
On Windows 7, the patch "Update.exe" works properly ONLY if launched using the command "run as admin".
Both latest & previous setup's "setup.exe" are set to "Admin" execution level.
I know InstallShield 2011 contains a new feature to specify execution level for patch... Is there any other solution than buying the last Installshield version?
Unable to set execution level in Patch Design
lavocat
, May 03 2012 15:34
