Starting an installer I need to check some product version stored at MinVersion and MajVersion DWORD values at the registry.
I filled in LaunchCondition, Signature and RegLocator tables.
During installation my MINVER and MAJVER properties get values like #1 and #5 (that's predictable). But when I specify a condition in LaunchConditions like
MINVER_PROP >= #1 AND MAJVER_PROP >= #6
or
MINVER_PROP >= 1 AND MAJVER_PROP >= 6
it looks like it does not work. It looks like it does not compare it as DWORDs but as strings.
What's the proper way to check a DWORD registry value in LaunchCondition?
Reg value & LaunchCondition
chum
, Jul 19 2010 21:06
Posted 20 July 2010 - 08:51
That's correct, Windows Installer performs string comparison :-(
If these were files then you could perform sort of a numerical comparison using the Signature table. But if these are just string values, you'll need to write a custom action to perform the numerical comparison.
Posted 20 July 2010 - 17:05
| QUOTE (Stefan Krueger @ 2010-07-20 08:51) |
| if these are just string values, you'll need to write a custom action to perform the numerical comparison. |
As far as I understand MSI can compare strings in LaunchConditions. That's mean I just can write a condition like the following:
MINVER_PROP >= "#1" AND MAJVER_PROP >= "#6"
but it won't work correctly in case the major version is 10 for example
Posted 22 July 2010 - 09:10
Yes, that's what I wanted to say.
if these are just registry values, you'll need to write a custom action to perform the numerical comparison
because a string comparison will fail as soon as there are more than 1 digits.
