How to perform Component wise Uninstallation?
Posted 15 February 2002 - 05:46
leaving others intact .
Whenever I tried to launch uninstalltion Program it uninstalls all the components.
Is there any way to do it?
Posted 15 February 2002 - 07:48
"It is not hard to alter the program block to event driven; at least since you sound like you already have the file groups destinationed (components were where the destination was in 5.5) and I would assume it compiles. So, all you really have to do is find the componentmovedata. Everthing before this goes in onfirstuibefore and everything after goes in onfirstuiafter (basically). Throw away the componentmovedata as it is done automatically after onfirstuibefore (and onmaintuibefore). I'd make a copy of the script file before starting. I bet then all your event functions get hit correctly. (I hate to be a pesimist but I have never seen the program block work correctly in 6.x and only read about problems from this.) "
SOURCE: http://www.installsi...rum1....ic=1154
Hope it helps.
