Avoid Language Selection dialog
vishwa
, Sep 06 2004 06:51
Posted 06 September 2004 - 06:51
Hi all,
Our product supports installations in 3 different languages, with English as default. Since adding the language packs, and the languages to support, whenever I start the install or uninstall, the language selection dialog appears at the start.
I want to control the display of the language dialog box. Depending on certain conditions, I want to decide whether the language selection dialog should be displayed or not. Is there any way programmatically to do it?
Also, is there any way that I can control the text in the language selection dialog?
thanks,
Vishwa
Posted 07 September 2004 - 06:43
setup.exe is responsible for that dialog, so it is displayed before your script starts. therefore you cannot programmatically decide whether to display it or not. You can however use a command line parameter to select a language. So what you could do:
- turn off the language selection dialog in InstallShield
- write your own exe (or CD Browser autorun program) that will display a selection dialog or not, with the text you desire
- this exe would then launch InstallShield's setup.exe with the appropriate language command line parameter
Posted 07 September 2004 - 12:04
Many thanks for your reply, but I still have a question..
How can I turn off the language selection dialog in Installshield?
Regards,
Vishwa
Posted 07 September 2004 - 16:09
In Releases view select your release. In the property grid switch Languages Dialog to No.
