Hi! All,
I need to register a .exe file as a service. To register that file i need to set a path in the Environment Variable. I used SetEnvPath and RefreshEnvironment from the sample code downloaded from here this works perfectly fine. i then register the .exe file as a service thru the script, the service is not registering. Is what i am doing correct?? why is not the file getting registered. i use the following code to register the file.
LaunchAppAndWait("\"" + TARGETDIR ^ "myfile.exe" + "\""," /Service",WAIT) < 0
Plz.....HELP......
Set path and registrer file as service
siva
, Jul 07 2004 07:39
