it is possible to delete the msi installer after installation?
Regards Marcus
Delete msi after install
MarcusAK81
, Nov 27 2006 10:24
Posted 27 November 2006 - 10:54
What exactly do you wish to delete? Which file, in which location?
Posted 27 November 2006 - 11:00
I make an example. I download a msi package to my desktop, i install it and after i want that this msi is deleted automatically.
Regards Marcus
Regards Marcus
Posted 27 November 2006 - 11:26
I don't think the msi package can delete itself. However you could add a remove entry to the "pending rename operations" registry entry (or call the MoveFileEx windows API) to delete the file on the next reboot.
Posted 27 November 2006 - 11:32
Hmm thats not good. I saw this feature by an self-extracting exe and so i thought it is also possible by an msi.
Reagrds Marcus
Reagrds Marcus
Posted 27 November 2006 - 13:00
If you use a custom setup.exe launcher, it should be possible to delete the MSI file after install, yes. the problem is that you would probably have to write such a launcher yourself, or use some sort of tool to create it.
