can anyone help me with setting default destination folder with Automation interface or cmd line parameter to IsCmdBld?
Robert
Posted 05 December 2001 - 15:53
Robert
Posted 06 December 2001 - 06:55
ISCmdBld.exe -p "Sample Project.ism" -d SampleProject -r Release1 -a Build1 -b "D:\Install Location"
p : project name (could be a relative path)
d : product name as given in the .ism file
r : release name
a : product configuration
b : build location (this has to be full path)
Instead you can put all this information into an .ini file and give that ini file for build.
Infact you can specify even more information.
I use it this way
ISCmdBld.exe -i SampleProj.ini
--- contents of SampleProj.ini
[Project]
Name=".\Sample Project.ism"
Product=SampleProject
BuildLabel=Build1
[Release]
Configuration=COMP
; to specify compressed or uncompressed (UNCOMP)
Name=Release1
SetupEXE=y
;whether exe is to be created or msi alone (y/n)
[Mode]
Silent=no
;silent build (yes/no)
[BuildLocation]
Path="D:\Install Location"
---- ini ends ----
Note: The path of ISCmdBld.exe must exist on the path environment variable. If not add it.
Hope this helps
Posted 06 December 2001 - 09:22
Regards,
Robert
Posted 07 December 2001 - 04:00
Posted 07 December 2001 - 13:32
Regards,
Robert
Posted 10 December 2001 - 05:49
