This is a strange problem ....
I ghosted a workstation and installed version 2.4 of our software on it. A desktop shortcut and a entry in the start menu are created. Both the desktop shortcut and the start menu display a 2.4 icon. I then uninstalled version 2.4 of our software. The desktop icon and the start menu entry are removed. This is expected behaviour.
Next, I installed the new 2.5 version of our software on the same workstation. The desktop shortcut and entry in the start menu should display a new 2.5 icon, but the old 2.4 icon is displayed. If I look at the properties page of the desktop shortcut or the start menu entry, it says the default icon is the 2.5 icon, but it displays the 2.4 icon. I tried changing the icon to the 2.5 icon from the properties page, but it still displays the 2.4 icon on the desktop. I try refreshing the desktop, but it still displays the 2.4 icon. I tried rebooting the machine, but it still displays the 2.4 icon.
Now, if I had upgraded to 2.5 instead of uninstalling 2.4 and installing 2.5, the 2.5 icon is displayed correctly.
The 2.4 version of our software used Installshield 6 and the 2.5 version of our software uses Installshield 7.
Does anyone know what's wrong?
desktop icon not correct after uninstall/install
dianemckenzie
, Jul 23 2003 23:21
Posted 24 July 2003 - 20:37
Try and delete (or move) the file shelliconcache in your Winodws folder. This will force Windows to re-cache all icons. There's also a similar option in TweakUI if you have that installed.
Posted 27 July 2003 - 23:09
Windows (all versions appear to have same bug) handling of icons is a bit flakey at times, I've found the easiest solution to be to rename the key in the "Icon" table...
Dennis Bareis (dbareis@No.Spam.gmail.com)
Free MSI update/creation tool (MAKEMSI):
http://users.cyberon...eis/makemsi.htm
