I've tried to make a custom action with WinInstall. I need to do the following; After the MSI package is done installing I want to call a KiXtart script (e.g. KiX32.EXE Script.KiX) to do some stuff in HKLM (so I hope that since it will be executed from and within the MSI package it will still have the proper rights to write to HKLM.
I've tried the example (http://seer.support....docs/234777.htm) to call a simple batchfile which can be found on the Veritas site to no avail, to call external stuff seems to be very poorly documented there!
Also, very important, I've got a working package at this time with the .MSI file, Program Files & Winnt directory. I want to be able to make a subdirectory to that structure (like KiX or similar) where I place KiX32.EXE and the script or scripts).
ANY help would be GREATLY appreciated!
