Dear All,
We are trying to trigger an executable after the completion of installation. The executable needs 2 DLLs for its operations. Say EXE is in "C:\Program Files\apps\exe" and DLLs in "C:\Program Files\apps\bin". In this case the EXE is not called. But if the DLLs are copied to "C:\Program Files\apps\exe", the exe is getting called successfully.
We have tried setting both the paths in the environment variable PATH. still it is not working
Please help us to solve this problem
regards,
Arun V
LaunchApplication
ArunV
, Aug 02 2005 06:57
Posted 03 August 2005 - 08:59
Well, that depends upon Dlls. If these are not static dlls, then, these should be registered before calling the exe. Try "Com Extract at build" for those Dlls, so that these would be registered on the target machine.
If these are static dlls, then these should be deployed in the same folder as of exe.
Hope this helps
Farrukh
Hope this helps
Farrukh
