how can I build an installer that only is executed once?
amg_soft
, Jul 31 2003 18:49
Posted 31 July 2003 - 20:15
You will need to explain your definition of 'once'. Do you wish to install one time and then never allow a modify, repair and remove? I think you need to allow a remove.
I can envision methods on a stand alone computer, but when you consider a workgroup or client/server install, those might be impossible.
Posted 01 August 2003 - 00:41
By 'once', I figuring he means a setup that can be installed on a PC, but then somehow "destroys itself" in some way to prevent any future installations--regardless of the PC.
Also, the supporting uninstall information would still be on the original PC, so you'd be able to remove it. I would just drop the modify and repair options from Maitenance mode.
Well here's a previous post on the subject, but it doesn't really have any good answers to this.
