Then, the directory structure looks like:
C - directory
|___product -A-directory
| |___product A
|___product -B-directory
|___product B
Also, the files of both the products are the SAME...only difference is that the command line of product A is different than command line of product B.
If, installation sequence is
1. product A,
2. product B
then if i try to unnstall product A ......it removes the files from folders but does NOT remve teh shortcuts!! i.e. after installing both products.... the FIRST UNINSTALL FAILS to remove the shortcuts!
Note:
1. The product code, packae code is different in teh two packages.
2. This is weird: After uninstalling first product i checked to see where the (left-over) shortcuts pointed to.....and they pointed to the FILES OF SECOND PRODUCT. i.e. Readme shortcut of product A pointed to product B's Readme file (AFTER) uninstallation!!
