Hi Experts
I'm building a Basic MSI package and have got most things working. I'm
having problems reading ini file data and then entering this into the
registry.
I've looked at the InstallScript example with a Custom Action which displays
a message with the contents from an ini file, but how can I pass that
Installscript string variable to the registry?
Here's what I have
ServerSettings.ini
[Server]
Name=JDSGLASGOW
Port=149
Site_UNC=\\JDSGLASGOW\SelfService
Site_URL=http://JDSGLASGOW/SelfService/
I require the Basic MSI setup.exe to read JDSGLASGOW from this ini file and
then enter it in the registry.
Many thanks
Pass ini file data to registry
jez123456
, Mar 07 2006 11:34
Posted 07 March 2006 - 15:05
If you are not very specific about using installscript, there are some windows API's which can be used to read the entry from ini file.
GetPrivateProfileString will help you read the value against a keyword in the ini file. Then you can use any registry API to key that value into the registry.
Hope that helps
Hope that helps
