Using an InstallScript MSI project I have the requirement that an install needs to make sure that the machine has AT LEAST "Sql Server Express 2008 R2" installed.
I know I can go into "Application Data -> Redistributables" and check the box for Sql Server. However as far as I know this only adds the exe for it, and does no logic for when to install it. Is my thinking correct there?
My plan was to write a custom action in C#, probably using WMI to check for versions of sql server, call it from InstallScript, and return a boolean flag to indicate if an install is needed. If it is needed then call the exe somehow to install it, and wait on it finishing.
Would this work? Is this the best way to do this? Or are there built in ways to do it in an InstallScript MSI project?
Minimum Sql Server version mandatory
pauldavidson
, Dec 20 2012 12:01
Posted 26 December 2012 - 12:08
If you add the prerequisite, it will check to see if the version is already present and only install if it is not. If your application works with an older version of sql if it is there, but you want to install the latest version if there's no sql, then you can modify (a copy of) the prerequisite using the prerequisite editor and tweak the detection logic in it.
