Hello,
I am using InstallShield Professional 11.5 to build a 64 bit InstallScript MSI installer. I am aware that the add/remove programs info is not populated correctly for a 64 bit installer using InstallScript MSI.
I have come across the following link which talks about it:
http://community.fle...3648#post453648
In the above link, a workaround was mentioned. The code pasted works fine. However Installscript seems to be resetting the values set using the codee again thus resulting in blank values overwriting the set values.
Is there any solution to this? Or should i assume that there is no way to fix this in InstallShield 11.5?
Any help would be very much appreciated.
Regards,
Kiran Hegde
Problem populating add/remove program entries
kirann_hegde
, Apr 09 2010 13:17
