Thanks in advance for not saying rtfm. I really have been reading and re-reading the msdn docs trying to build my first msi. I'm missing something fundamental regards the shortcut table. The Directory_ attribute specifies where the shortcut will be place by the installer. But it must be an FK to the Directory table where you specify the directories you need installer to build for you. So, ah, how do you tell msi that you want a shortcut to appear somewhere else, outside the dir structure you have defined, e.g. the Start Menu, the desktop, etc ?
Sorry again for the lameness of this post and feel free to direct me to other docs/resources for getting started with msi.
Steve
beginner not understanding shortcut table
steve_pence
, May 30 2007 10:15
Posted 30 May 2007 - 11:32
You can add any directory structure with any of the pre-defined system folder properties as it's root. They're all documented here:
http://msdn2.microso...y/aa372057.aspx
You probably want to define DesktopFolder and ProgramMenuFolder for your current needs (with any required sub-folders, of course), but it's a handy link to keep.
Good luck,
Gareth
Good luck,
Gareth
Posted 30 May 2007 - 13:21
I thought of that, but I didn't see how I could add a directory that wasn't under the root of my target. I realize now it is the directory table I don't truly understand. But I'm on the right path now. Thanks much for your kind and quick response.
Anyone know of a clearer writeup on how the directory table works than MSDN provides?
Posted 31 May 2007 - 10:35
Rob Mensching blogged multiple times about the Directory table.
http://blogs.msdn.co.../21/431294.aspx
