Thanks for any help.
Use Custom Action return value
tgebbie
, Aug 20 2001 21:57
Posted 20 August 2001 - 21:57
Is it possible to use a custom action return value and set a public property within the property table with that return value?
Posted 20 August 2001 - 22:06
You can set a property from your CA, e.g. by calling MsiSetProeprty. Depends on what your CA is (script, dll, ...)
You can use the return value of a DLL call in the way you want if you call this DLL as "standard DLL" (not "Windows Installer DLL") in InstallShield Windows Installer Edition.
Posted 20 August 2001 - 22:13
The custom action is as follows:
Type: 34
Source: DATA <-- Directory path parent INSTALLDIR
Target: "[DATA]CSI.exe" PAR1=?? PAR2=XXX
This custom action is launched based on if the Database feature has been selected to be installed and is launched with a Button Control in the SetupCompleteSuccess dialog. The file is a standard VB EXE file. Would I have to add code to the actual VB Source Code for this project or can I get the return value of the custom action in a different way?
Thanks.
Posted 21 August 2001 - 07:43
In MSI exit codes are used to indicate success or failure of the custom action, so they can only be predefined values like ERROR_SUCCESS, ERROR_INSTALLFAILURE or ERROR_INSTALLUSEREXIT. If you want to get the exit code from an EXE and store it in a property, you need to wrap the exe (e.g. a DLL that calls the exe, gets the exit ocde and stores it in a property). You could do this in a script based custom action, too.
