**NEWBIE QUESTION**
I have a question regarding variable replacement in a text file. In this instance, I am prompting the user for IP address and Port number, and have created dialogs for that. I have defined variables in the InstallScript to hold those values for later use. The intention is to take those values and insert them into an IIS "web.config" file.
Inside of this file I have the replacable text in this form exactly:
<add key="LoginMode" value="[SITETYPE]" />
The [SITETYPE] reflects a variable defined in the script and is tied to the Setup Type. Overall, the setup runs fine except the variables do not get replaced in the script. I do not know what I am doing wrong. (See script segments below).
#define DEFAULT_IPADDRESS "0.0.0.0"
#define DEFAULT_PORT "0000"
#define SETUPTYPE1 "VA"
#define SETUPTYPE2 "COMMERCIAL"
#define SETUPTYPE_TITLE "Wireless BloodCare Installation"
#define SETUPTYPE_MSG "Please select your setup type based on your environment."
#define SOURCE_DIR "C:\inetpub\wwwroot\WBCServices\\"
#define SOURCE_FILE "web.config"
// setup default status
Enable(STATUSEX);
return 0;
//Begin the String replacement in neccessary config file.// //
// The following function will configure the "\WBCServices\web.config" file //
// based on values given by the user. It will configure for VA or Commercial //
// the appropriate Authentication service and add additional information per //
// the developer release notes. //
//Find and replace operation 1: SITETYPE
FileGrep ( SOURCE_DIR ^ SOURCE_FILE , "[SITETYPE]" , svReturnLine , nvLineNumber , RESTART );
nLength = StrLengthChars( svReturnLine );
nStart = StrLengthChars( "<add key=\"LoginMode\" value=\"svSiteType\"/>");
//Find and replace operation 2: SERVERIP
FileGrep ( SOURCE_DIR ^ SOURCE_FILE , "[SERVERIP]" , svReturnLine , nvLineNumber , RESTART );
nStart = StrLengthChars( "<add key=\"VistaServer\" value=\"svIP\"/>");
//Find and replace operation 3: SERVERPORT
FileGrep ( SOURCE_DIR ^ SOURCE_FILE , "[SERVERPORT]" , svReturnLine , nvLineNumber , RESTART );
nStart = StrLengthChars( "<add key=\"VistaPort\" value=\"svPort\"/>");
// Close the file.
if (CloseFile (nvFileHandle) < 0) then
MessageBox ("CloseFile failed.", SEVERE);
end;
If anyone can help, I would appreciate it.
**NEWBIE FileGrep QUESTION***
is_support
, Sep 16 2004 20:18
Posted 17 September 2004 - 13:24
This should be:
#define SOURCE_DIR "C:\\inetpub\\wwwroot\\WBCServices\\"
Also I don't see where you are actually replacing the text?
You may also want to look at the sample code "Replace a String in a File" at http://www.installsi.../en/isp_str.htm
Posted 17 September 2004 - 13:31
Thanks Stefan, I'll try that out shortly. It makes sense that if IS can't find the right file no edits can be made...
