I have an NT4 sp5 machine. The Windows Installer doesn't work correctly after Exchange Server 5.5 installing on it. I can not upgrade the Windows Installer to the version 2.0. The error message is "Wrong OS or OS for the application" (I use intsmsiw.exe which was downloaded from site). I unregister msiexec.exe, delete msiexec.exe, msi.dll, msihnd.dll from the system folder and tried to install version 1.2. It reported that the installation was completed successfuly, but looks like it is not true. My installation doesn't work propertly, any custom actions are not executed.
I have found an article #Q264652 on a microsoft site which said the SFC.dll existing in a system folder may cause this problem. I don't have this dll.
My question is does anybody know may another dll's (perhaps from Exchange Server 5.5) causes this problem?
Any help would be great.
Thanks a lot,
Windows Installer Engine and Exchange Server 5.5
Irina
, Jul 18 2002 16:27
Posted 18 July 2002 - 16:27
Irina Shirinsky
Software Engineer, Heroix Corporation
http://www.heroix.com
Posted 19 July 2002 - 16:28
the error message you describe is usually associated with installing the wrong version of the MSI Engine on the wrong OS. there are two major versions of the MSI engine ( one for the 95/98 the other NT/2000/XP ). is it possible that someone renamed the file ( called instmsi.exe instmsiw.exe ) ? try and download a new version of the instmsi from a validated source....
IF THIS IS NOT THE CASE
you can try the following. unregister the msi.dll and msihnd.dll using the RegSvr32 -u msi.dll and RegSvr32 -u msihnd.dll. this will cause the regiastry entries for the MSI dlls to be removed. with the instmsiw.exe use the /t parameter to extract all of the files to a temp directory. instmsiw.exe /t:C:\Junk reregister the msi files using the RegSvr32 msi.dll and Regsvr32 msihnd.dll. run the MSIInst.EXE from the temporary directory and you should be back in business...
Posted 19 July 2002 - 20:43
Thanks for your answer.
1). I have tried the correct instmsiw.exe file. The problem was my machine has NT4 service pack 5 which not enough for MSI 2.0, it needs NT4 service pack 6 or more.
2). Of course, I have done all this procedures before. I guess the problem was in my installation package, the last version doesn't work correctly, but the current version works fine for now.
Irina Shirinsky
