Hello,
I created a patch of a Standard InstallShield 7.04 Installation for the first time, with no problems.
But when I tried to apply this patch, by executing the created Update.exe file, I received the following warning, after the "Preparing to Install" dialog: 1: This installation can not be run by directly launching the MSI package, you must run setup.exe
What does this warning mean, what setup.exe should I be running instead?
Note1: When creating the patch, the patch creation wizard created administrative images of both the previous package and the package which it is to be upgraded to.
Note2: I have also tried creating a patch without creating the patch launcher and applying the patch using the MSP file with the same results.
Thank you in advance,
Ian Frangs.
Unable to apply patch
Ian
, Mar 13 2003 12:45
Posted 14 March 2003 - 12:55
Are you sure you're using version 7.04? I'm asking because in 7.02 there was a known bug:
http://www.installsi...bugs_isd702.htm
Error Messages When Applying a Patch
Posted 17 March 2003 - 12:38
I am using Installshield Debeloper 7.04.
But i have solved this problem by creating un uncompressed install of the latest package and referring to this using the patch wizard.
Thanks.
Thanks.
