Hello!
Please, add clarity about REINSTALLMODE property.
According to Microsoft documentation, it useful when installation required running from the source package and re-caching the local package.
Additionally, recommended not use the v reinstall option code for the first installation of an application or feature.
Unfortunately, I did not find description of behavior when v reinstall option is not set.
When I need to set v option in routine? (Reinstall, first install, small update).
Can I set REINSTALL and REINSTALLMODE property in Windows Installer database, without command-line parameters?
More about REINSTALLMODE property
AntonS
, Sep 22 2004 14:49
Posted 22 September 2004 - 15:28
An InstallShield docs explain further, that v forces re-cashing from msi package to target system. Thus, every minor update needs to be set v reinstall option?
Posted 23 September 2004 - 17:28
That's correct, every minor update that is shipped as full .msi file needs to set the v in REINATLLMODE. If it ships as a .msp patch this is not required. You cannot set the v inside the package it has to be set outside. Setting REINSTALLMODE=v doesn't hurt for a first time install.
You shouldn't set REINSTALL=ALL for a first time install, as this will only reinstall what was installed before, which in this case is nothing.
